System Monitoring Center
Hakan Dündar වෙතින්
unverified
Multi-featured system monitor
*** Announcement (31.10.2023): End of support for System Monitoring Center ***
- Optimized for low CPU usage
- Supports ARM architecture
- Hardware accelerated GUI
- Free and open source
Notes for Limitations:
Notes for Flatpak Support:
2.26.0 අනුවාදයෙහි වෙනස්කම්
5 months ago
(Built 5 months ago)
ස්ථාපිත ප්රමාණය~13.14 MiB
බාගැනෙන ප්රමාණය3.67 MiB
ස්ථාපන135,591
