System Monitoring Center
von Hakan Dündar
unverified
Multi-featured system monitor
*** Announcement (31.10.2023): End of support for System Monitoring Center ***
- Optimized for low CPU usage
- Supports ARM architecture
- Hardware accelerated GUI
- Free and open source
Notes for Limitations:
Notes for Flatpak Support:
Änderungen in Version 2.26.0
vor 5 Monaten
(Build vor 5 Monaten erstellt)
Installierte Größe~13.14 MiB
Download-Größe3.67 MiB
Installationen135.816
