System Monitoring Center
by Hakan Dündar
Multi-featured system monitor
- Optimized for low CPU usage and fast start
- Supports ARM architecture
- Free and open source
Notes for Limitations:
Notes for Flatpak Support:
Changes in version 2.9.0
6 days ago
Installed Size~12 MB
Download Size3 MB
Installs29,662
LicenseGNU General Public License v3.0 only
