fan-control screenshot
- Save configuration
Note: After installation, you will need to add the necessary udev rule to your system for this to work. See the GitHub page for more details.
Changes in version 0.1.3
23 days ago
(Built about 23 hours ago)
Installed Size~21.13 MiB
Download Size8.32 MiB
Available Architecturesx86_64
Installs4,384
